I am running a Buick based Fast system on my other car and have had to fabricate the crank and cam sensors. The way the crank sensor had to be made there is no adjustability on it and I had to guesstimate where to locate. I'm pretty sure it is within 5 degrees either way. The only way to get the timing dead on is to move the crank reference angle in the software from the Buick setting of 10 degrees. How much room do I have to play with before something else gets affected? I got the motor fired up and it runs well so it is somewhere close, but I have not zeroed the timing yet. 5 degrees can be a big deal on a turbo motor.
Long story short--where does the 10 degrees reference angle come from?
Greg Kring
Greg Kring
