blue beast
- Mar 20, 2010
455 Buick Master Performance Engine Kit High Comp w/Cam
WBK253
Master Performance Engine Kit for 1970-76 Buick 455ci engines.
Hastings Moly Piston Rings
Clevite rod bearings
Clevite main bearings
Durabond cam bearing set
Fel-Pro complete gasket set with intake valley pan gasket
Cloyes- Street True roller timing set .250 double roller 3 Keyway
Melling HV Oil Pump Kit
Sealed Power High Compression Hypereutectic Piston Set H392NCP .130" deep, 4v relief -23cc Volume; 9.5:1 CR w/68cc @.030 Limited sizes from SpeedPro
Brass Freeze Plug Kit
Speed Pro Camshaft Lift .469/.493; Duration 290/300 214/224 @ .050 112 lobe
Matching Valve Springs
Johnson Lifter Set
MY MOTOR IS OUT OF A 70 ELECTRA , IM GOING WITH AN ELDERBROCK DUAL PLAIN INTAKE HEADERS FROM TA PERFORMANCE 800 CFM CARB AN THE ORIG BIG PORT HEADS .... WILL I HIT 400HP AT THE FLYWHEEL?
WBK253
Johnson Lifter Set
