I have no tunability complaints with the 009s. I just didn't much care for running near static @ 3rd WOT... this was when I had my TA49. Also, I got a great deal on ~100 mile set of 50s off a friend with a cammed & ported engine that went to 72s (hint, hint).
ttypenssrider, you have a cammed & ported engine, run alky, are considering a stretch or FM, and eluded to a 60 series turbo. IMO the 009s will not be enough when you decide to turn it up, and you will. If you aleady have and can't return the 009s, use them. If you haven't bought them yet, save your pennies for a week or two and get 50s or 57s. Per Racetronics website:
009s: ~$50.00/ea = $300
MSD 50s: 57.50/ea = $345
Siemens 57s: $65.00/ea = $390
When I had my '49 & 009s (stock block / head engine), I would be @ 105-110% duty cycle @ ~23psi & 24-26*. 50s dropped that to ~85%. Now with the PTE 52, it is back up to nearly 90% with ~23psi, 23-25*... a tad higher than my liking. I'm going to replace the supply line for more flow, and get more voltage to the pump. That will (hopefully?) hold me over for the current set up, but when my ported / slightly cammed engine comes together it will probably be inadequate, so a Bob Bailey Low-Z ECM has already been procured. I just need to decide on my injector, which will probably be Siemens 72s.
:-Dean
