Z
zerosoul
Guest
I'm new to the forum. just want to say what's up!
I just put in my new aquamist injection kit in my 94 supra turbo, I'm using the 0.7mm nozzle spraying 50/50 water-alcky.
the problem with Aqusmist kit is it does not allow user to control pump speed, insdtead, different nozzle sizes are used to control the amount of injection.
I was told by the seller that I should inject around 20% of my fuel flow....is that correct? if so, how should I calculate my 0.7mm flow rate?
BTW, I'm running stock 550CC injectors.
thanx for the help!
Jonas
thanx for the help!
Jonas
