how much stall for a pt-72-1 turbo
49-blues
like it says-aproximately how much stall will i need around if i upgrade to a pt-72-1 turbo-thanks
On my car, a full weight GN. With M/A heads and 218 cam, a 3500 A/C 9in was not enough. It was a Q-trim though. I would go 3500 or more. Really depends on how much low end your cam makes. Bruce`s 9/11 from PTS is a good choice. He will work with you to create the right set up.
Brian
i ll be running a 208/224 cam and will probably go with a 911 converter so i figured about 3500 or more ,so i guess i ll be talking to bruce.just wanted some real world input from guys that might have this turbo.and it will be the q trim, thanks
Depends on intendted usage. I may have something for you to try and see if you like. Let me know asap as what i am thinking of will not be around long.
Bruce
We4
