how mutch is it worth ??????
robsquezn
all fresh 87 stock block race preped 3 builet caps studs. 10-10 crank shot peaned rods.trw pistons.new hd roller cam & lifters /valve springs.fully ported turbo heads with big valves .
hv cover .oil pan /sencers.wire harnes.computer. t&d 1.55 shaft mounts. buick 6 valve covers.new 85 lbs inj.ported lower.accufab
upper & accufab 70mm tb.all sencers.mas air.down pipe.wast gat.new atr headers.down pipe.ign&modual.dist.every thing but a turbo...
the turbo was going to put 70gtq but precion lags let me know
what u think this mtr was pro built & all readdy to go low 10s
thanks robsquezn@sbcglobal.net
im sher iv forgoten a part or two??????????
Almost the same as mine
Except ive got Champion Irons w/ matching intake and hemco plenum with stock tb(not for long). Id say $5k to $7k if you have receipts.I know you probably have at least $3k in ms labor but the economy is so bad right now.Good luck in selling it:D
economy is bad.....:rolleyes: :rolleyes: Says who.................
Thats a thread of its own..
I think you should be able to get $4500.00 the way it sits..
You might consider parting it out....;) $$$$
Matt:cool:
