Learning to hate these Powermaster brakes, now I see why folks do the conversions. Cobbled up parts to fix it including used but working (at least I'm told it was before I purchased it) master cylinder. Got everything hooked up (that plunger is a real bit--!) but can't bleed it. With full reservoir nothing comes out of the two front lines regardless what I do. I learn that the high pressure line has to be primed, that dealerships used to have a J tool that would pressurized system then air could be bled from other lines. I can't figure how to bleed the high pressure hose, mostly 'cuz way it situated. If disconnect it & have someone prime it with ignition & brake peddle, how does one re-connect it without getting air back in? After all the work so far hate to have towed to dealership (& afraid they'll tell me they can't do it after all!). Help, any one know for certain how to bleed it after complete replacement?
