how to check if it really is a 10.5 10 bolt? and not an 8.2?
Pavell
how to check if it really is a 8.5" 10 bolt? and not an 8.2?
i dont want to get screwed, I hear people swap out the GN rear ends when they sell them.
how do i check?
You mean to see if its a 8.5" ring gear 10 bolt.
But i forget, did you try searching?
Here you go!
yes thats what I meant, thanks
what other scams do people pull ? what should i check?
Axles, drive shaft, Chip, injectors, fuel pump, FPR, cam, turbo, converter, transmission, motor, knock sensor wire cut or sensor loosened, suspension, adding stop leak . . . And the list goes on. Sad but true.
This is why I do my own work when possible and only trust 3-4 shops in the world with the keys. The more you know . . . .
I have a buddie who is a wrench. He owns an 87 T if I can't do it he is the only shop I will take it too.
