How to check is coil pack is getting 12 volts
remove the connector and check the P and M pins for 12v (pink/ blk stripe wires)
P is last pin on end of connector , M is two pins from P toward firewall
I tried to get the pin-out info on Turbo Regal Web Site but I did not see it. Call Jason at RJC Racing and he probably knows which pin(s) should have 12-volts. I would think you could just use meter and run through the pins and find it.
