I'm in the process of rebuilding my stock turbo (87 GN) and was wondering if there is a safe way to clean the carbon build-up on the turbine wheel? I have access to a glass bead machine where I work and would like to know if this would be a safe method. I am also porting the elbow & enlarging the wastegate hole while I have it apart. There was .015" end play in the shaft but the turbine or compressor wheels have not made any contact with the housing.
Thanks Mike
Thanks Mike
