shocker998md
- Jan 8, 2009
So ive replaced all of the vacuam lines on the car with new ones, and zip tied all of them as well. Some times the car will idle VERY high, like 1800rpms and this is after its warmed up and all of that good stuff. My tps and iac are good, so im thinking vacuam leak. Now i go out today to poke around at this and what do you know, its not doing it. Ive got a TT chip and the car normaly idles fine, but sometimes its idling high. Any body have some ideas? And what is a good way to check vacuam leaks? I want to say you can spray throttle body clean around gasket areas and the motor will stumble a bit, but i may be wrong. Any input would be great.
Kenny
Kenny
