Hydroboost Conversion
Supercharging The Vacuum Booster Was An Idea That Buick Did Not Want To Be Liable For. When The Hose Blows Off The Vacuum Booster, Buick Knew That Not All People (ladies In Particular) Would Not Have The Leg Muscle To Stop A Heavy Fast Car With No Power Assist. The Car Would Be Wrecked. If The Rubber Valve, Inside The Check Valve Is Forced Into The Booster, Then There Is No Check Valve, And Under Supercharging, The Vacuum Booster Would Blow Apart. Like Sticking The Shop Blow Gun Inside It.the Other Possibility On The Soft Pedal Would Involve Using The Powermaster Pedal. With It's Higher Pin Location, It Would Cause That Mushy, Springy Pedal. The P/m Uses A 1.250" Master Piston, And The Regal Vacuum Booster Uses A 24mm (15/16") Piston. The Pedal Must Be Changed. The Hydroboost Uses The Same Pedal As The Powermaster.
