How to install cruise/turn signal
gold69charger
I just bought a NOS cruise/turn signal leaver for my 87 G.N. Does anyone know how to remove the old one and reinstall the new one? I looked at the colume and I see no screws to remove the cover? Any help would be great. Thanks, Joe
When pulling the wires through the column they may hang up...don't try to force it or you may lose the guide wire from the stalk wire inside the column....then you're screwed...just pull it back out a little and try again...may take several tries...just be patient...
The guide wire I used, hung up in the column and I ended up compressing the column and releasing the lock plate (and snap ring), but the factory procedure works, just be patient.
