How to repair your leather wrap steering
My leather on original steering wheel was pretty ugly plus there a piece missing a few scratches etc....you know a well worn steeing wheel that suffer from too much boost and fun!!
So here the how to on repairing the leather on your GN or T's
The key ingredient is cyanoacrylate and 'What the h*ll is that you say????' (well its simply humm...Krazy glue, yup )
Krazy glue will blend to the leather and keeping it all together. Your steering wheel will remain quite soft (if I may say).
It took my about 3 hours on and off to get it ready to paint. I very happy of the final result!
My steering looked like this, wasn't pretty at all :
Ok here what you need:
Sandpaper 80, 180 and 220
1x tube of Krazy glue
Some degreaser like brake clean
Couple of hours of your free time.
First thing to do:
Clean your wheel with the degreaser, make sure its clean and oil free
Then use the 80 grit sand paper and scuff you repair area.
Next use the Krazy clue to fill the little cracks. For bigger hole little I have, you need to built it up meaning a little at a time. Let it dry, put a little more and so on.
------ Little tip here: Use the Krazy glue in thin coat only, this way you will have less runs and lot more easy to sand.
Next sand with the 180- grit sandpaper. Fallow the contour on the wheel and look for ridges and high/low spot. Always try to blend (key word for this job!!!)
This part is a repeat step many times...
Next, use more Krazy over the complete area. Again in thin coat.
------- Next tip: You don't want to see and feel the skin under the leather (white stuff under the grey leather) because it will show on the finish product. You want a smooth surface.
Next, almost done preping.
Recoat the repair area with another thin coat and sand with 220 grit sandpaper. Sand/Scuff all your steering leather to help the paint stick. You want a smooth feel without any visible marking/scuff....
Notice how the missing pieces is now filled and smooth.
Next, clean the steering again with alcool base product like brake clean
then apply the paint in thin coat only. Repeat 3-5 times depending on your steering. I personnaly applied 4 coats of SEM color match paint.
Speaking of paint; I used a custom mix SEM aerosol spray can base on a 1983 Buick leather sample. My local parts store did the mix.
SEM code 3089
GM Code 16CN
Here the result! Look like new again!
My total cost:
30.00$ for the SEM spray can
4 hours of labors
HOPE THIS HELP!!!
