Not positive, since I always forget between resettings. Try holding in the reset button in the passenger side fuse panel for 5 seconds while the car is running (or at least ignition on). Good luck.
Originally posted by Scott 97.5 GS Not positive, since I always forget between resettings. Try holding in the reset button in the passenger side fuse panel for 5 seconds while the car is running (or at least ignition on). Good luck.
This is correct for the GS. I just had to do it last week. Turn the ignition on, hold in the reset button for 5 sec., the light will blink 3 times and go out.
