How to swap out injectors
john saleeby
I'm replacing stock with 60's. Free practical advice is welcomed. Does the entire fuel rail have to be removed or can one side be done at a time? Things to do/not do? Thanks in advance!
John
on mine the fuel rail is one piece, U shaped. make sure the whole area is SUPER CLEAN when you do this. real easy to drop drash dirt grease chunks in your motor or injectors at this time!! just remove the retaining bolts and gently pull it off being careful with the lines. also when you put things back together make sure the inside of the cups are clean and oil the o rings on the injectors a little before you slip them in. this allows them to move more easily into place and seat properly.
good luck!
