70Firebird/TTA
- Aug 11, 2002
Guys
I believe that I already have the answer...but would like opinions....in a nutshell I purchased my TTA off a friend of a friend who was clueless about what had been done by the original owner who bought the TTA new back in 1989. The original owner was the past owner of a Turbo shop in Orange County area (Turbo City)...and my attempts to contact the shop only provided basic info such as "certain intake/exhaust mods" were performed...but they would not get into specifics. I have varified that the chip and exhaust system isn't stock and a GN buddy pointed out that my electronic wastegate control module was disconnected. The 2 valuum connections on the electronic wastegate control (I believe that's the name of it) do not have anything running from it. When I look under the T3 Turbo I can see that the wastegate has a long arm that apears to be adjustable via a nut on a shaft. Is this an adjustable wastegate?? Would a stock TTA booste correctly if the wastegate was disconnected from the wastegate control???
The TTA currently boosts at 16.5 lbs and boosts very quickly (per my GN buddies who went for a ride). It this wastegate is aftermarket and adjustable...the million $$$ question is why the wastegate wasn't adjusted to boost to 18-19lbs...???????????
Still learning about my vehicle...comments/suggestions/insight is appreciated.
thanks
David
thanks
David
