Buick Grand National 1987 loaded with engine and suspension parts for a nice street & strip setup. The GN engine has been professionally built and tuned by KDK Performance in Orlando and produced 517 RWHP & 450 FT-LB Torque @ 22 PSI with a conservative tune. I have the Dyno runs data from the tuning sessions showing the results. The car can run high 6’s in the eighth mile. The car is still street legal. The A/C has been deleted and other light weight parts have been added. I have a lot time and a great deal of money invested in building the car, see below the list of parts. It is a fun fast car, but it needs a new home. Anyone that has had ever purchased a performance GN knows that it is priced to sell.
Asking $13,600 obo
Located in Central Florida
Contact info- clfast@gmail.com
Pictures - clfast - Photobucket - Video and Image Hosting
The Parts List
3.8L forged balance & blueprinted engine built by KDK performance (Orlando FL Buick Performance)
Forged Speed Pro Pistons
Bullet Main Caps
ARP Bolts
ARP Head Studs
High Volume Oil Pump
Turbo Saver Oil filter System
Comp Cams 269HR Hydraulic Roller Cam
Specifications RPM range 1500 to 6200 Duration 269 264
@.050” 218 212 Lift .511 .504 112º
Champion Aluminum GN1 Heads
(New K-Motive spring and 3 Angle Valve Job by KDK)
Scorpion Roller Rockers
Harden Push Rods
Fully Ported Intake and Plenum
Accufab Throttle Body
Duttweiler Front Mount Intercooler
TE-45a Turbo from Limit Engineering
ATR 3.5 Down Pipe
Turbonetics External Waste Gate
RJC Under Drive Pulleys
60# Injectors
Aeromotive 1000 Fuel Pump
10 AN Fuel Feed and 8 AN Fuel Return
BRF Transmission perfromance built 200 4R
Art Carr 9” 3200 Stall Converter
Stage Right Trans Brake
Drive Shaft Safety Loop
6 Point Roll Cage
Griffen Aluminum Radiator
Fiberglass Hood
ATR Fiberglass Front bumper
Southside Upper/Lower Control Arms
TA Aluminum Diff Cover
Moser Axles
Stainless Steel Magnaflow Exhaust
Extreme Extender 2 Chip
GEN 2 Translator with Fuel Adjustment features
ECM modified to allow low Impedance Injectors
3.5 Mass Air Meter
Champion GN1 Valve Covers
Autometer Boost, Oil, Temp Gauges
New Fiberglass Bumper Fillers Front & Rear
Asking $13,600 obo
The Parts List
Bullet Main Caps
ARP Bolts
ARP Head Studs
Harden Push Rods
ATR 3.5 Down Pipe
60# Injectors
6 Point Roll Cage
Fiberglass Hood
Moser Axles
3.5 Mass Air Meter
