hr bar fit with atr 3"?
bird
is anyone using the hr anti roll bar with the atr 3" dual exhaust, will the bar fit without modification, looks like it would be tight to me?
thanks
rich.
nevermind, talked to paul at h&r, does fit with some minor tweaking.
i had a hard time getting it to fit with my atr single shot.
the single shot was soon replaced with hooker duals.
i think 3" duals are not worth the time or money
2 1/2 fits better and has better sound control
surej
Boost, what was difficult in fitting with the single. I have a KB 3"single shot, and am planning on installing this bar soon. Brian
Hmm, whay sort of effort was involved, and what had to be modified? (if anything).
I was going to install an HR bar first, and then a 3" ATR singleshot second ... would this sequence make it harder, or easier, or about the same effort?
the axle tube brackets for the bar hit the pipe before it bends over the axle. we couldnt reposition bracket and the pipe became wedged between the bar and the upper control arm.
i now use the hooker exhaust, but had to make custom hangers
Assuming you get it installed properly and it doesn't bind up on you.
And again there could be clearance issues with that bar as well.
And the install requires welding vs. bolt in.
Nice try tho..... ;)
Originally posted by ILLEGAL REGAL
LOOK INTO WOLFE RACECRAFT FOR AN ANTI-ROLL BAR, NOT SURE IF IT WILL CLEAR BUT DOES WORK MUCH BETTER THAN THE HR
i dont see how it can work better. my car launches dead straight and i dont hear any noises either.
My car also launched straight with stock boxed control arms...now did it leave level, no, it looked stupid. Wolfe anti roll bar has made it leave level and doesn't look like a capsizing boat.
im sorry, straight and LEVEL.
both will work, but the hr is an easier install
Not sayin hr doesn't work, just sayin that from what I've seen on cars the wolfe works better. But now to go back to stock the hr is better than plasma cutting the wolfe off. Either way is better than nothing just depends on your skills and know how I guess. :cool:
I have the wolfe bar and it didn't clear the 3" single shot. Doesn't look like brain surgery to make it fit correctly though. Just a little tweak this way or the other maybe.
