huge parts list F/S
updated list
here is the update list with available parts.
stock parts
alternator---------------------------20.oo
alternator Y bracket-----------------25.oo
aluminum bracket--"2"---------------65.oo each
battery cable "positive"--------------25.oo
belt tensioner-----------------------70.oo
boost solenoid--"2"-------------------60.oo each
boost Y hose GM---------------------10.oo
cam sensor--"2"----------------------60.oo each
coil pack mounting plate--------------25.oo
coil pack hoop bracket----------------25.oo
crank sensor with mounting bracket---35.00
cruise control with 1 cable & mount---25.oo
EGR plastic cover---------------------5.oo
ECM----------------------------------45.oo
fuel lines from frame to engine--"1"-----50.oo each set
HD adj. wastegate actuator stock style-60.oo
intercooler stock--"2"------------------45.oo each
intercooler side bracket----------------25.oo
intercooler lower bracket---------------25.oo
intercooler shroud real good condition---55.oo
intercooler fan--"2"--------------------35.oo each
injector harness-----------------------35.oo
fuel rail-------------------------------35.oo
oil cooler adapter with nut-------------25.oo
oil cooler lines--"2"--------------------40.oo each set
power steering hoses------------------30.oo
power steering pump--------------------65.oo
power steering reservoir-----------------45.oo
plenum upper--------------------------30.oo
rocker shafts---------------------------35.oo
throttle body complete-----------------85.oo
up pipe--------------------------------20.oo
vacuum block with metal lines-----------20.oo
water pump new GM--------------------20.oo installed started removed
water pipe clamp-----------------------5.oo
water pipe with clamp------------------30.oo
water pipe fitting @ intake--------------5.oo
water pump pulley-----------------------20.oo
stock parts powder coated black
alternator Y bracket-------------------------25.oo
aluminum bracket----------------------------75.oo
belt tensioner--------------------------------85.oo
engine lift bracket----------------------------15.oo
H/D wastegate actuator----------------------65.oo
oil cooler adapter with nut---------------25.oo "coating is chipped in places"
water pipe-----------------------------------40.oo
water pump pulley---------------------------25.oo
water pump GM-------------------------------25.oo
intercooler bracket "side"----------------------30.oo
aftermarket parts
auto meter carbon fiber 2 1/16" gauges
boost--------------------------------30.oo
oil pres. elec.-------------------------30.oo with send. unit
water temp---------------------------25.oo with send unit
oil fill cap "metco"---------------------25.oo
