Intercooled88s
Moderator
- Aug 10, 2004
Parts added to list this week
BRF valvebody $200
GN Steering wheel good for a core to recover(no horn ring or center) $40
86-87 Lower intake manifold $130
Intercooler brackets both for $50
Map light $20
Walbro 340 $50
Turbo stock elbow $20
84-85 valvebody with TPS,IAC motor,vacuum manifold $50
stock 86 chip $30
stock 84 chip $20
mast for manual antenna $30
underdrive pulleys(crank and alt) $40
86-87 Crank pulley with adapter $30
Battery hold down $10
Tranny oil cooler(external) $20
Power Master minus accum ball and switch $50
87 GN upper door panels in good but not mint condition $60
3 switch panel that fits in ash try,in console, with 3 switches $15
CCCI Adapter harness(harness lets you use 86/87 Ignition module with 84/85,plugs into hot air harness $25
Misc.
GN rearend(8.5 non posi , drum to drum withdriveshaft ) $500
Driveshaft for 8.5 rearend $50
Transmission cross member $40
87 GN good running 109 short block $700
87 Engine complete, has a rod nock $2000
BQ coded GN transmission 48k $300
BRF tranny $500
Stock 200 4r tranny pan $30
86-87 GN wheels good for cores all 4 for $120
INTERIOR
Steering column(floor shift) $120
85-87 Gn Steering wheel(good to have recovered) $50
85-87 GN console $140
Plate on console that goes around the shifter $40
84-87 GN shifter $35(needs T handle)
86-87 GN seats $400
86-87 GN lower door panels $60
Grey rear sail panels(panels around the quarter windows) for t-top car in great condition
$40 for both
Grey Third brake light $25
85-87 GN seat belt set(10 pieces) $70
I have all the plastic interior pieces for a marroon or grey car with either t-tops or hard
top .
Nice grey arm rests $15 for both
Nice blue passenger visor with lighted mirror $25
Gauge surround $35
radio surround $25
Stock GN radio $50
Maroon dash pad $110
Blue dash pad $120
Grey dash pad $110
T-TOP trim around the t-tops on the inside of the car in Red, Maroon, or grey , all 6 pieces
$100
ENGINE PARTS:
86-87 Turbo $150
86-87 Turbo can be used as a core $75
84-87 Turbo elbow $25
86-87 MAF $80
85-85 ECM $40
86-87 ECM $70
Engine frame mounts $35
86-87 dipstickand tube$40
86-87 Factory Oilfiller tube and cap $30
86-87 Scoop for airbreather $20
N/A crank std./std. $40
109 Block $300
crank $325
.020/.020 Turbo crank fresh from the machine shop $150
stock 8445 heads needing rebuild $40 a set
84-85 GN intake $40
86-87 fuel rail $40
84-85 fuel rail $25
Any year injector harness $35
84-85 valve covers $35
86-87 valve covers $35
cam position sensor just the lower part(no cap) $30
86-87 MAF $100
84-85 MAF $45
84-85 AC compressor $40
84-85 Alt $35
84-85 turbo adaptor $25
84-85 crossover pipe $35
84-85 Alt $30
84-85 engine wire harness $100
86-87 engine wire harness $175
Any other harness on the car e mail I have them all
86-87 Power steering pump $60
86-87 AC compressor $70
86-87 Belt tensioner $70
86-87 Alt. $60
86-87 Main accessory Bracket $80
84-85 Main accessory Bracket $50
Small plastic guide that holds the posi bat cable to the lower front cover $20
84/85 to 86/87 conversion parts(all the original GN parts you need to convert over from 85
to 87) $1500
Oil cooler adaptor with nut $35
Timing cover $30
Turbo rods(2 dot) $40 a set of 6
Turbo flex plate $25
Turbo oil pans $35 each
84-85 control module $50
84-85 coil pack $40
Body & Misc.
PowerMaster brakes assembly $200
Vacuum brake assembly +pedal $65
GN Front bumper $130
GN rear bumper $100
Alum. rear bumper reinforcement $80
86 GN grill $90
85 GN grill $60
85-87 T-type grill emblem $20
84-87 GN fenders(GM) $80 each
Non Key locking t-top $90+shipping for the set
86-87 Locking t-tops+keys $200
T-top bags $35
Lock set(all 3 locks with key) $60
Drivers missor $20
Passenger remote mirror $40
Blackout door handles $25 for both
GN Spoiler(GM not after market) all 5 pieces $200
GN tail lights with blackout trim $100
Quarter glass with blackout trim $85
3 piece windshield blackout trim $30
3 piece rear window blackout trim$20
Black wheel well trim $50 each
Turbo plastic wheel wells $80 each
Any other blackout piece e mail me I have them all
GN hood $95-$150
AC lines $45
Fuel pump hanger/sender $50
Turbo gas tank $40
GN sway bars $30 each
windshield wiper assembly $15
Complete heater box $100
BRF valvebody $200
Map light $20
Walbro 340 $50
stock 86 chip $30
stock 84 chip $20
Misc.
BRF tranny $500
INTERIOR
86-87 GN seats $400
$40 for both
top .
Gauge surround $35
radio surround $25
Stock GN radio $50
Blue dash pad $120
Grey dash pad $110
$100
ENGINE PARTS:
86-87 Turbo $150
86-87 MAF $80
85-85 ECM $40
86-87 ECM $70
109 Block $300
crank $325
84-85 GN intake $40
86-87 fuel rail $40
84-85 fuel rail $25
86-87 MAF $100
84-85 MAF $45
84-85 Alt $35
84-85 Alt $30
86-87 Alt. $60
to 87) $1500
Timing cover $30
84-85 coil pack $40
Body & Misc.
GN rear bumper $100
86 GN grill $90
85 GN grill $60
T-top bags $35
Drivers missor $20
GN hood $95-$150
AC lines $45
Turbo gas tank $40
