BLACK MAGIC RACING
formerly turbo_canuck
- Jul 18, 2001
Take it all as one huge parts lot and save $$$$!!!!
86/87 parts:
-Stock heater core- $50
-Stock intercooler - $75
-Stock shifter cable - $35
-turbo heat shield (3) - $20 each
-Stock accessory bracket (2) - $75 each
-Stock crank pulley - $30
-Stock throttle cable bracket- $35
-stock rocker shaft assemblies- $40 pair
-stock intercooler shroud - $20
-pair of stock 8445 heads - $150
-2 driver side intercooler bracket- $25
-3 passenger side intercooler brackets - $30 each
-passenger side intercooler bracket cut for stretch intercooler - $20
-stock maf sensor - $ 150
-stock oil filler tube + cap (2) - $20 each
-stock crank fan - $20
-clear parking lenses - $15
-stock turbo (core)(2) $75 each
-stock front sway bar - $40
-stock balancer - $75
-stock water pump pulleys (2) - $20 each
-stock coil pack/module mounting plate - $30
-2 stock turbo cranks - $250 each
-BRF transmission (core) - $275
-CZF transmission (core) - $225
-Chrome tail lights - $60 each or $100 pair
-Blower motor- $40
-Flexplate (2) - $35 each
-Stock Throttle body no arm, spring or iac- $ 35
-Stock plenum,$ 30
-Engine block (2) standard bore $ 275 each
-stock passenger side header (2) - $60 each
-stock cam sensor - $55
-Driver's side tail light assembly (chipped corner) - $60
-passenger side taillight (lens only, no bezel) - $45
-rear defrost window- $75
-driver side fender -$45
-Pass. side fender -$45
-Stock intake - $275
PERFORMANCE PARTS:
- Stock style adjustable fuel pressue regulator (gold) - $55
-2 -4"long 3"i.d. hose-blue- $15 each
-3" to 4" reducer hose-blue- $20
-4"long 3"i.d. hose- black $15
-6" long 2.5" to 3" reducer-black- $20
-2.5" to 3" reducer hose-blue- $20
-orange stripe street brawler converter - $275
-NEW chrome ds breather/ oil fill tube - $ 35
-Lokar trans mount dipstick + tube- $50
-ATI treemaster 9" fuel/blown converter,TH400, 3800-4200 stall - $750
-3.5" stub downpipe, 4" long, build your own DP, internal gate. - $185
-Wiseco forged pistons for 4.1, clearanced for stroker- $200
-Extended 14 bolt oil pan, deepened 1", $75
-Turbosmart manual boost controller - $50
-FAST Jumper harness w/ wbo2, 3bar map harnesses- $ 275
-ATR external wastegate- $125
-Pair of stage 2 valve covers - $65
84/85 PARTS:
-engine accessory bracket - $25
-braided down pipe - $20
-4 '84 t-type wheels - $ 200
- '83 regal header panel - $175
- Pair of MINT chrome headlight bezels for 81-84 - $125
V-8 BUICK PARTS:
- autometer mech. oil press. guage - $25
-New frame pads for 455 swap into regal, skylark- $70
-0-15lb fuel pressure guage (autometer sport comp mechanical)- $ 25
-30-0 hg vaccuum guage (autometer sport comp mechanical)- $25
-stock 350 exhaust manifolds- $80
-350 Alternator/ac pump bracket- $35
-350 4 barrel intake - $75
INTERIOR:
- Dark green steering wheel- $50
-cluster bezel, with turbo 3.8 emblem- $60
-Turbo Dash cluster- $80
-pair of t-top bags - $50
-Dash pad, great shape - $100
-Front and rear GN seats, driver condition. driver power, doesn't work - $450
-GN CSII lower door panels, driver condition - $100
According to my math, there's $7925.00 worth of parts here. I'll sell EVERYTHING!!! for 3800!!! that's less than HALF!!! I'd like to sell everything on one shot, and i can deliver to bowling green. If things start getting sold seperately, i WILL NOT ship transmission cores, engine blocks, dash pad, etc... but delivery to BG is no problem whatsoever.
86/87 parts:
-Blower motor- $40
-Stock plenum,$ 30
PERFORMANCE PARTS:
84/85 PARTS:
V-8 BUICK PARTS:
INTERIOR:
