HVAC question
ctflash1
Hey guys quick question about my 85 GN. Im sure all of the ventilation is the same on all of these cars but does anyone know off hand why I cant switch from defrost to vent to floor, etc.. Is the damper vacuum or electric? I havent even began to look yet just figured I would throw this out there cuz Im sure one of you have had this problem before. Thanks for any info, Steve
I slid my control unit out the dash and saw that the round assembly with all the vacuum lines had cracked. I repaired it with some JB weld, but I believe they make a replacement part. Either way, verify all the vacuum lines are secure and not leaking on top of the control unit.
Thanks for the info. I'll pull that control unit out and check it out. Thanks for the help it saves me from starting from scratch troubleshooting it.
Also check all the vacuum check-valves; they are the little gray/black wafer looking doo-dads ; they can go bad and cause these symptoms vacuum check-valve.jpg
Do_O
