hydro boost, autometer, MAF, DP, etc.
Eric Stauch
Nasty87
Hey guys, just cleaning house. If you need better pics or any information just PM me. I accept PayPal or money order. Shipping is extra unless otherwise noted, If using PayPal please add 3%. Thanks guys.
Please contact me via PM, It is so much easier to keep track of who was first again please contact by PM NOT posting on this thread. Thanks
1. Front wheel trim from 87 GN great shape no dents but a paint chip or two, new coat of paint and these would be perfect. $50.00
http://i628.photobucket.com/albums/uu9/thenasty87/wheeltrim.jpg
2. Stock valve springs from 87 GN comes with springs, locks and retainers. nothing wrong with these just looking to move them, Cheap! $5.00
http://i628.photobucket.com/albums/uu9/thenasty87/valvesprings.jpg
3. Stock 200 trans pan, not warped and comes with factory bolts, the two that hold the shift cable bracket are different but included. $10.00
http://i628.photobucket.com/albums/uu9/thenasty87/transpan.jpg
4. Stock tensioner, comes with tensioner and sping, no bolt. Still in bag. $5.00
http://i628.photobucket.com/albums/uu9/thenasty87/tensioner.jpg
5. Stock fuel pressure regulator, brand new but not adjustable. $10.00
http://i628.photobucket.com/albums/uu9/thenasty87/regulator.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/regulator2.jpg
6. Stock 87 BH MAF, known good BUT, the case seems to be coming apart, might could glue back together? $20.00
http://i628.photobucket.com/albums/uu9/thenasty87/maf1.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/maf2.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/maf3.jpg
7. Stock air intake hose, no holes but a wire or two is showing, driver condition or back up piece. $FREE (pay shipping)
http://i628.photobucket.com/albums/uu9/thenasty87/intakehose.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/intakehose2.jpg
8. Stock injectors, set of six, around 60k miles, ran fine when pulled, tired of them sitting around. $20.00
http://i628.photobucket.com/albums/uu9/thenasty87/injectors.jpg
9. Master cylinder and Hydro-booster, both brand new (reman) units, got the part numbers for these from O SO LOW and his junk yard donor list. Picked them up from the local parts store, lines not included but the numbers can be found on the donor list and ordered through any parts store. $70.00
http://i628.photobucket.com/albums/uu9/thenasty87/hydroboost.jpg
10. IC fan hub for underdrive pulley. $FREE (Pay shipping)
http://i628.photobucket.com/albums/uu9/thenasty87/fanhub.jpg
11. Stock oil drain back from 87 GN, no cracks and comes with brass fitting for block. $8.00
http://i628.photobucket.com/albums/uu9/thenasty87/drainback.jpg
12. Stock down pipe off 87 GN will come with stock elbow and spring bolts (not pictured) also was cut before converter but made two stainless steel flanges one for the down pipe and one for the converter to make removal easier. will come with stock converter also (not pictured) converter is completely hollowed out but has matching flange to mate with down pipe. also has O2 bung. $50.00 (will work with you on shipping due to size)
http://i628.photobucket.com/albums/uu9/thenasty87/downpipe.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/downpipe2.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/downpipe3.jpg
13. Bracket that bolts to fire wall then power master bolts to. good shape. $5.00
http://i628.photobucket.com/albums/uu9/thenasty87/bracket.jpg
14. Three Autometer gauges 2 1/16", PRO-COMP Ultra lite series, one new still in box oil pressure gauge with electronic sending unit, one electronic water temp gauge brand new but no box (all sending units and hardware included), one air fuel gauge brand new but no box and O2 NOT included. $55.00 for all three
http://i628.photobucket.com/albums/uu9/thenasty87/autometer3.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/autometer.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/autometer2.jpg
15. C5 Corvette brakes, Two new (reman) front calipers (not pictured but can get pics upon request) and two new Wagner brand rotors. A great brake upgrade BUT will require bracket a hardware that is NOT included but available through Kore3.com $50.00 for all of it! (will work with you on shipping due to wight)
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_205453.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/IMG_20101102_205524.jpg
NON BUICK PARTS
16. Stock "truck style" 454 chevy rods, great shape and with ARP bolts. $45.00 SHIPPED!
http://i628.photobucket.com/albums/uu9/thenasty87/rods.jpg
http://i628.photobucket.com/albums/uu9/thenasty87/rods2.jpg
17. Chrome MOROSO big block chevy valve covers one pair, great shape just need to be cleaned, $ 25.00 SHIPPED!
http://i628.photobucket.com/albums/uu9/thenasty87/valvecovers.jpg
I will take
I'll take this
I would to know how much for the brakes shiped to 64465. Are the rotors 13.5"?
