SignUp Now!What is the "left" pedal off of???The pedal on the left is what i used for the hydroboost and the right is my vacuum. As soon as i took the booster off of the the left pedal it returned where it should be.
Its the same padal that comes with the powermasterWhat is the "left" pedal off of???
What mc did you use?I had this problem when I used a aluminum MC from a different application. All I did was put a flat washer on each stud between the booster and MC, problem solved.
Yep. I may just put a trans brake in the gn and that would solve the problem too. I've got another car i can put the hydroboost in.
