SignUp Now!Update
From idle you can only feel minimal assist, almost like old school manual brakes.
you're my kind of guy- why spend $800 when you can get the same thing for $100?Wow, i can`t see spend $800.00, but if you have it like that, then my hats off to you.
Thank goodness my installation with parts cost $125. the lines and fitting is what cost me most of the money. I bought the my hydroboot used from the e-z pull for $10 (work excellent),off a 1997 chevy astro van. no cutting and drilling. the asto van unit bolt up to the TB powermaster firewall plate, perfectly.
Your set-up still look nice and clean. but i can`t see $800.00, because i KNOW TOO MUCH....![]()
Can`t complain for $125.00. Its best to use TEFLON braided line on the brake system, when compare to RUBBER braided line. DO NOT USE RUBBER BRAIDED LINE WITH ANY OR DOT 3 BRAKE FLUID ON THE HI-PRESSURE SIDE OF THE HYDROBOOST.
Doug, I noticed you said you cut the wheel back and forth while the car is idling. I was reading on the instructions I have with me that it says to cut the wheel back and forth about 40 times with the car not started. Heard of this?
Dang, that sounds like a lot of work! 40 times with the engine off?!?How are you supposed to drive the car after this project if you can't move your arms anymore?
Hi
The early 90's Astrovan HB is more straight out from the firewall. For the later 90's, it is angled downwards. I don't know when they changed body styles.
go back to the parts store and check out 92/93/94 Astrovans.
Hope that helps... dave
Now, I went back to the powermaster assembly and disconnected the two wire connectors and the
brake lines.
Just ordered a Hydroboost system... what happens when you unplug the PM wiring harness? Do either of these get reused at any point? Does the brake light come on and stay on with the Hydroboost? What about the 30 amp fuse for the PM pump; does that simply become useless? Thanks and great documentation, I'll be under the hood this weekend trying to get the ole girl up and running...![]()
