DIY.... budget conversion on an '87 GN. I am looking on the possibilities for getting an "off-the-shelf" replacement powersteering pump to HB line that is close to the correct length..... doesn't matter if it is exactly correct.... just as long as it has the correct ends on it... and is near the correct length....
IMHO you could tweak the ends to make it fit....
The HB unit I am looking to use is a '95 Astro.... just like Tin Man has used.
Pump to HB line.
I think I need a 16mm male o-ring fitting on the pump end... and an 18mm male o-ring fitting on the HB end. I am not sure the length I might require.... but have found replacement HB (PS to HB) hoses with the correct (I think) 16mm x 18mm fitting size.....in these lengths:
93 Astro - 43-1/2"
95 Astro - 34-3/4"
96 Astro - 30-1/2"
HB to Steering Gearbox line.
I think I need an 16mm male o-ring fitting on the HB end.... and a 18mm male o-ring fitting on the gearbox end. Again, I am not sure of the length.
93 Astro - 40"
96 Astro - 33-1/2"
The return line should be easy... not too woried about this.... I just want to find some over-the-counter lines that I can make work to greatly reduce the cost of the conversion.
Can anybody tell me what length lines would be close?
Pump to HB line.
93 Astro - 43-1/2"
95 Astro - 34-3/4"
96 Astro - 30-1/2"
93 Astro - 40"
96 Astro - 33-1/2"
