Hydroboost upgrade help
Made a Bracket that bolted to the PSC and then used a bolt that was on the inner fender
Added a second plate that went under the window washer tank
I made a mock up mounting bracket from PVC angle stock (it was easy to cut & shape) , attached it to the factory PS reservoir support bracket on the fender.
After massaging the shape till I was happy with the fit , I copied this to a piece of aluminum angle from Lowe’s / Home Depot.
Will re-post some pics since they were lost when this site crashed
Here are some pics
Looks great, thank you very much for the pictures! I'll do the same this winter.
