mearly65 said:
Just for my own education, how is a .42 TPS at idle fine? Wouldn't that translate into around .38 or so with key on, engine off?
.42 at idle is just about perfect. You could set it to .35 at idle and it would still idle fine. When the engine fires up, the ECU looks at the voltage coming from the TPS and stores that value as the "idle value". When the ECU sees a voltage higher than the idle voltage, it knows that you are pushing the throttle.
However, the maximum voltage that the TPS can be with the engine idling is 0.45 volts. If it's set to a value higher than 0.45, the ECU programming will not interpret the gas pedal as being completely released, and it will not go into its idle control routine.
However again, you want your idle TPS voltage to be as high as possible, because that adjustment will get the TPS voltage as high as possible under WOT. This will ensure that the ECU goes into power enrichment, etc. when it should.
Best thing to do is get the TPS to be about 0.40 to 0.42 volts with key on engine off. When the car is started, it will be about 0.42 to 0.44 volts, which is perfect. Just make sure the TPS goes back down below 0.45 volts every time you blip the throttle. If it's occasionally sticking above 0.45 volts when you release the throttle, idle problems will result.
Explanation is a bit simplified, but should illustrate the point.
Hope this helps...
Mike
Sent from my HTC Droid Incredible using Turbo Buick
