I Can't shift into Park
WH1Driver
I have hooked up my transmission to my rebuilt motor. I have no floor shifter as yet so I'm using the shift linkage at the column. I can't adjust the linkage so that it will shift all the way up into park. Does anyone have any suggestions has how I can fix this. I have consulted the service manuals I have and they say to set both transmittion and column to neutral and set the linkage. However the column as no specific indent for the gears it just has play. Thanks for any help you guys can provide. Regards, Nathan
Hey Nathan...
it can be done hang in there you'll get it... try a search on here it has been discussed previously. ;)
