i dont follow directions well, new powerlogger question
fleebag
so i just put in the powerlogger and updated the sm as well. and tried it out today but dont think i wired up everything?
the only external hookup i did other than the pl on ecu was the white wire from sm to the small thing with screws, lol
am i also suppose to tap into my 3bar map as well? if so can i piggy off the pac controller?
i do not see boost on the file and i knock pretty bad
but think i am missing wiring up something.
also, what else should i hook up to get the full effect of the pl ?
TT alky chip, alky control with pac
208 roller, 1.65 rckrs
billet caps
alum gn1's, ta headers, 3.5" dp
66 turbonectics 4/2.5, ptc slic
70mm tbody
thanks in advance
ok i think i did this one right?
i know my mph is wrong for some reason(gauge is about 20 more than sm) and my tps is only going to 3 something
i will wire up the map tomorrow and will install aem wb nextweek
tia
Yes you can tap off of the green wire that connects to the MAP sensor to the PAC to turn on the alky controller. This will be used for a boost signal.
See my response above. Also check wideband AFR if you have a wideband.
Wideband, EGT, I already mentioned the MAP sensor hook up (supplies boost reading).
thanks for advice, i ordered a aem wb from full throttle so i should get it next week.
once i get it in i will post a file so i can get some help.
thanks again
can i install the wb in the extra bung on my header? i have ta headers and it has two bungs with the o2 in one but the other is plugged.
i see pics that show people put it in the dp but can i just put in header?
NO! :eek:
The environment in pre turbo is much to harsh. The Wideband would never survive there. Too much heat and back pressure.
The down pipe is the most ideal place, and the further from the turbo the better. AT LEAST 18" is safe.
