Started the Gn the other day and noticed the BLM's at idle were 148-150...after the car ran for a while they came back down a bit.  Drivability and wot looks great..O2's look good at cruise but here is the catch. after a short cruise blms are 141, After idling for a while the blms creep back up..it seems the hotter the engine compartment gets the higher the blms.  If I shut down the car for a bit and then restart it the BLM's are at 148 for several minutes and then work down to 142.  I have checked the lines for a leak but found none.  Vaccuum is 16.5-17 in park.   Any suggestions are welcomed
TIA
Bob
			TIA
Bob
