65malibuss
- Dec 8, 2001
I'm in the process of installing a Turbo Buick drivetrain into my 96 Impala SS and I have a few questions for anyone who has already performed a swap.
1. Is there a way I can adapt the existing quick disconnect fuel lines in my Impala to the fuel lines that are connected to the Buick fuel rail?
2. I was considering using a Holley Commander 950 Pro engine management system. Is anyone using this system with a Buick 3.8L turbo engine? If so, is it necessary to use a different cam or crank sensor or coil? Or will it not work at all with this engine?
3. Will the Caspers VSS signal sender thing work with the stock Impala speedometer? Or if I put the Buick gauge cluster in my trunk and hookup the speedometer cable and VSS unit and send the output from that to my Impala speedometer will that work?
4. Will the stock Impala tachometer function properly if it is connected to the tach signal from the Buick ignition module?
That's all I can think of now. Thanks for any advice anyone has.
