Last week I got the car running only to find coolant was getting in the oil . I tore the timing cover back off to find out what had happened. I had first thought it was a head gasket but it only started once I put it back together. Turns out the new cam button ate a hole in the front of the timing cover. Heres the fun part. The aluminum piece that broke off went into the coolant passages in the motor. It's a good size chunk. I had my fingers on it and almost had it out and it dropped on back into the block. I tried using hose water to pressurize it out but no luck. I don't think I can forget about it. I have no idea how to get it out
