I think i need a bottom feed or worse..
dsa87gn
Tranny shifts are great at part throttle. At WOT they dont seem
to be fast enough, dont snap like part throttle.
Did alot of searching here...tried the extra quart.
did make some difference.
I didnt notice this with my stock tires since they just busted loose.
but i have bfg drag radial ojn now and they stick like hell and dont break loose..
where do i look next ?
a ckperformance 2004r valve body recalibration kit would be a wise decision
where is the info on your website about this.. (p/n or link)
anything else to consider ?
update
I tried setting the TV cable back toward the firewall a click
but it keeps ratcheting back to set position when I pull throttle WOT.
Took my drag radials off and put my street tires back on.
When I do a WOT romp it lights em up 1/2 way thru 1st and keep spinning right thru most of second. Don't notice any slide on the 1/2 shift.
With the drags on, I don't get any spin and the 1/2 isn't sharp at WOT. Fluid is nice and red..
The extra load on the tranny seems to be my problem.
