I bought a T-type parts car very cheap because a mechanic had diagnosed it with broken rings because it was blowing smoke out the breather. After blowing a ton of headgaskets myself I was pretty sure what the problem was. Today I finally got around to pulling the intake off and sure enough the headgasket on the #3 cylinder is sticking straight out and to top it off it's not a steel shim and the fire ring is too narrow to be a composite turbo headgasket so I assume someone installed non turbo gaskets. I almost feel bad for getting it so cheap knowing it was probably just a blown headgasket. I'm half tempted to install it in my car and bolt all my good stuff to it until the 4.1 is ready.
