After fixing a clog in my fuel return line which was causing abnormally high fuel pressures, I was unable to start the engine unless I held the TB plates open the a little.
After the engine revs up and continues to run, I can let go of the TB lever and bring it back to full-closed without killing the engine.
When the engine is running, I watched various screens for IAC position and TPS and IAC vs CTS. Moving the line on the Throttle Follower screen, Start IAC Pos vs CTS screen, and Idle Speed vs CTS screen doesn't have any "real time" effect on how the engine runs.
Is there anyway to test the IAC's actual movement?
Thanks,
Owen
Thanks,
Owen
