iac question
skostur79
ok tested my iac its dead ,
will the 86-87 work at all?
anyone here tried?
84-85 is 3 times more , just thought id check
it is the same part i used it when i swapped over to the 87 engine.
IAC for Hot Air and IC are different as listed.
Application IAC - GM PN
Hot air 25530695
IC 25527077
looks like i had a 86-87 in there i put the new 85 back in
and it idles
but still high at 950 counts good at 30 (yes base idle was set)
the chip says dyno tech stage 3
any one know that co.
would the idle functions be set higher?
thanks for the 2 that responded ,
Check ALL hoses for vacuum leaks.
IAC motor may be suspect. Clean the TB with some carb cleaner and make sure yout TPS is set. Check for a sticking throttle. Drive the car for a bout 10 miles and reset your IAC and TPS after the drive.
