Do the IAC sensor on our cars go bad ,if so what are the symptoms.Last week I checked my IAC reading on my ScanMaster and it was at 33 so I decided to adjust it down to 15(TT chip recommends between 10-30) .After every adjustment on what looks like a idle adjustment screw I shut the car off so the IAC can reset then started it up to see where it settled.After I got it down to 15 I readjusted my TPS at idle .42,wot 4.48,I did this with engine warm in park.I then took it for a 10 mile cruise and rechecked the IAC and TPS,then after I did a wot 3rd gear blast I rechecked IAC and it was oscillating from 50-54 then it settled at 51.After letting the car sit for about 30-40 minutes I then restarted the car got it up to temperature and the IAC in park was at 15,why is it changing so much?Am I doing something wrong? Thanks,ikle.
