IAC valve
6pk2go
I believe that I need to replace the IAC valve I have cleaned several times and it shows wear on the pin so I don't believe that it sets completely. I have a miss or surge when the car is cold and seems to go away when it is warm. My question, can I just install a new valve and will the computer make the adjustments automatically. I read about the "counts" which makes no sense to me aand I don't yet have one of the computer programs to read errors or the counts.
IAC
I had the exact same problem with my car, except it was reversed.. When it went into closed loop, it would idle poorly and not too responsive. When changing the IAC, it would be best to reset the base idle and check to make sure the TPS is adjusted correctly... :mad: I believe when you said counting, you were refering to grounding the ALDL port and counting the flashes of the "service engine soon" light, however I coul be wrong. When my IAC died, there were no codes stored in the ECM, so if thats what you're talking about you will no get a stored code for ECM failure on the 84/5 ecm. Hope that is some insight :cool:
____________________
85 WH1 with the Grand National package
Ta33 turbo, 2.5"Uppipe, walboro 307 FP, martone Adj FP reg, Ultratrans rebuild with performance mods, 2800 stall convertor, Art Carr RV shift kit
Member of the Manitoba Grand National Association.
Sounds like an O2 sensor issue to me ... hmm.
I love BFH's technical description of IAC counts :) I think counts just refers to how much the IAC motor is operating... the more counts, the more air the IAC motor is pumping around the throttle blade.
Hey BuickTV6.. I notice you're in MGNA... if I may be so blunt, who are ya? Welcome to the board by the way... I'm Dave, also in MGNA, so far I manage/host mgna.ca. When did ya join the club? Were you at any of the meetings this year? Also, I'm a computer tech/programmer too :)
Dave
