ok I just thought of this today and it might be a very stupid idea but I just wanted to ask if anyone ever thought of it or if it would even work.
ok after both hoses are pulled off the throttle body that flow the coolant through it and you use one of the hoses to route it back to the larger hose, the valve ends on the throttle body are still open
this was my idea
the hoses that are used to tap into the vacuum block to go to a boost gauge could be routed so one end connects to one of the valve ends and the other just connects back to one of the valve openings for boost gauge or vacuum block or back to the side of the car
what I am basically saying is to somehow route the vacuum tubes so they flow air through the openings in the throttle body where coolant used to be
I could be wrong, but wouldnt the air have a colder charge then the fluid even if it was 1 or 2 degrees difference?, theoretically cooling the air that flows into the throttle body better then the warmth of the anti freeze coolant warming the air temperatures?
please respond as I have just thought of this now
and tell me what you think about it
thanks
Carl
this was my idea
thanks
Carl
