I spun the no.6 rod bearing on my 86 T-Type.  It is the orignal engine and has 90,xxx miles on it.  I want to rebuild the bottom end on it but need some ideas.  The car will not be driven very much and for the most part it is basically stock.  I am going to budget for around $2500 for the project.  I would like to make the bottom end a strong, good foundation to build on in the future.  As I get the money, I would like to get larger turbo, intercooler, heads etc. For now I will be reusing all the other stock parts and want to focus on the block for now.  I plan to do all the work I can myself except for the obvious machine work.  I have very long term goals of 500+ hp so I want to build a block that can handle this.  Is this possible within my budget?  I want to stay away from a roller cam for cost reasons.  How strong are the stock parts with a girdle?  Since I already have to turn the crank, resize the rods, replace the rings, etc I was considering the GN1 stroker kit which is basically an entire rotating assembly for around $1900 plus machine work. Are the parts in this kit strong enough to handle 500hp?  Anyone have expierence with these strokers or are they a bad idea?  How much machine work is needed with this kit?  Your ideas and input would be helpful.  Thanks
