Nov 5, 2018 #1 TireFryer Boost Loading...... Joined Dec 21, 2001 Messages 1,488 In trying to locate my oil pressure sender, I came across this black "bell" looking sender up above the oil filter. I have never seen an oil sender (if that is what this is) like this. Can anyone help me identify this sender? TIA
Nov 5, 2018 #2 S ScottHeidinger Active Member Joined May 2, 2015 Messages 743 That is a aftermarket oil pressure sending unit looks like vdo but there should be a wire on that threaded end with a nut holding it there Sent from my iPhone using Tapatalk
Nov 5, 2018 #3 TireFryer Boost Loading...... Joined Dec 21, 2001 Messages 1,488 There is a wire attached via an elbow which seems to be pointed down in the pic. It goes to a SW oil pressure gauge... So is it a VDO or SW sender?
Nov 5, 2018 #4 S ScottHeidinger Active Member Joined May 2, 2015 Messages 743 Probably all look the same That is oil pressure sending unit
Nov 5, 2018 #5 ek02 Well-Known Member Joined Jan 31, 2008 Messages 1,226 It might be SW. VDO looks similar but they are usually gold in color and have an offset stud with a nut on it.
Nov 6, 2018 #6 captndave737 Well-Known Member Joined Feb 14, 2006 Messages 1,199 VDO makes 21 different senders in 7 different configurations! http://www.vdo.net.au/media/189570/2016-vdo-catalogue.pdf Could be SW as well. https://www.stewartwarner.com/produ...itches/?fwp_type_2_checkboxes=pressure-sender
Nov 6, 2018 #7 TireFryer Boost Loading...... Joined Dec 21, 2001 Messages 1,488 Thanks for all the input - all very helpful.
