Identify This Wastegate Solenoid
Joel A. Russo
Can someone tell me if this is a HD or standard.
Wish I had an answer for you, but to clarify, that's a wastegate actuator, not a solenoid. The solenoid is the electrical component mounted up on your valve cover.
Put some reglated compressed air to it, if it STARTS to move around 11-12 psi. it's a regular one, if it starts to move at 14-15 psi. it's an HD.
There's a third version with even stiffer spring but I've never tested or used one.
