jpwalt1987
- Nov 9, 2003
I have been noticing that my AFR at idle isnt staying the same from day to day. One day it will be about 14.2-14.7 and then the next it will have -22%correction and be at 12.xx. I have the VE table for idle at 7. This is with 95lb injectors @45psi static and a 224/224 solid roller cam. The idle RPM is @850 There is no temp correction influencing the VE table when it acts up. Is it realistic to expect this combo to idle at 14.7:1 ?? I hate to go lower on the fuel pressure because I would think that the higher pressure would help with atomizing the fuel a bit better. I may be wrong though. I need to check and see at what RPM closed loop operation happens, but I know it is not at idle. I am thinking about going down to a smaller hydraulic roller cam and some smaller injectors to help with the driveability but that cost money I dont have right now. I want to make the best of what I have.
I am at a loss for now. Any ideas?
