stangbangin69
 - May 17, 2008
okay, first i got a 86 gn. mods... scanmaster, fmic, te44, motron 60's tt chip, aftermarket cam, 3" dp w/external wg, ported and polished 8445's, t.b. and intake. homemade cold air intake. fuel pressure set to 44lbs (line off) and overall fuel added like 2.8%
the iac and tps set correctly. when the car is sitting in park it will go from normal idle (800-825) down to 650-700 rpms. idle's real slow and "lopes" down like it's almost dying out. it acts like your pulling a choke or something (if it were carb'd). once you rev it up or put it in gear the rpms come up fine. every now and again the rpm's won't come up quick enough and it will die when you put it in gear.
it does not throw any malfunction codes.
anything i'm leaving out just let me know and i'll post it. thnx anthony
