Engine smokes at idle. Fresh everything. Eliminated possibility of fuel or coolant. Definitely oil smoke. Turbo is fresh and not damaged from break in of engine. It has a special no bypass filter set-up. PCV is now vented as a "road draft tube". Both valve covers vented to atmosphere. Plugs fouled black in short time use. Wet black oil at header flange to head seal. This engine is very fresh with only a few hours of running time, and no high load operation. I pulled it back out and on inspection I found oil on the valve stems. The head gaskets were a poor match at the oil drain holes. The block and heads both do not align well with gasket holes. I am relieving the block area near the oil drain holes to enlarge the passages for better gravity oil drain.I have opened up the old head gaskets to use as a mock up and template for the new ones. I will be opening up the new head gaskets's drain holes to max. I have bell mouthed the oil drain holes in the heads. The heads are now at "Head werks" for a thorough check. I believe I am not the only one who is having some issues with poor oil drain from the heads. I'll update this thread when I get it back together.
