Nov 9, 2010 #1 S skidman 3 turbos,no money Joined Aug 16, 2010 Messages 138 I bought a Champion angled iac. Car used to idle good. I now have an 1150 RPM idle and iac counts are 0 . Cant find any gasket/vacuum leaks. Has anybody seen this or am I THE ONLY ONE? Skidman.
Nov 13, 2010 #2 P pajo Member Joined Jun 21, 2003 Messages 469 + I would think if your IAC was not damaged durring installation you will need to reset it and adjust your idle.IAC Reset Procedure
Nov 22, 2010 #3 S skidman 3 turbos,no money Joined Aug 16, 2010 Messages 138 Found the problem. Intake is stock,Champion EGR block off plate leaked, causing vacuum leak. A little RTV took care of idle. Skidman.
