No big deal if you want to review or not.
Combo:
Stock Long Block
Turbo 5831
42.5 inj
30psi
Alchy Inj
Hot Wired XP pump
New O2 Senor
I can see several issues that I suspected so I'm in the process of figuring out the best method to solve them. The TPS reads lower on PL than it does on my Scanmaster so I'll have to adjust that again.
These two runs compare fueling changes in my TT chip to compare O2's and injector Duty Cycle.
The default fueling in the TT chip in the BLM cell is 128 and the first run shows that run, just scroll to the end of the run to see it.
The second file shows after I changed the BLM cell to 150 adding a lot more fuel.
The boost reading on PL was 30-31psi but I'm not sure it was really that high. I need to compare the voltage off the MAP sensor to see how accurate it is. The last time I had my boost gauge hooked up it read 26psi (it was not connected for these runs) and that's what I expected to see but it's a lot higher according to PL..
I also added a third file that shows false knock while sitting in my driveway. All did was stab the throttle real fast and the KR showed up. This is the BS I've been fighting so I'll have Knock Ignore enabled.
Happy Looking
ks
Combo:
Stock Long Block
Turbo 5831
42.5 inj
30psi
Alchy Inj
Hot Wired XP pump
New O2 Senor
Happy Looking
ks
