If you're using AlkyControl and Boost Harness...
Good info. Did you by chance consult Ken before posting his boost harness circuit to the world?:eek:
No, I've been trying to get ahold of Ken for a few days now with no luck. The pieces are all there for anyone to see, it's not like they were potted or anything. Besides, I don't think anybody could build one for what they go for new ($49.00). The reason I diagrammed it was because mine broke and I needed to make repairs (the wires flexed enough to snap a solder joint).
That said, I did add the ground wire from TPS terminal "C" to the MAP terminal "A" and it works fine now. This will allow the harness to function either way - boost or MAT - and still trigger the Alky regardless of function.
Russ.. great info..
The MAP not only needs power but a ground as well.. :D
I guess that voltmeter just paid for itself.
